Hi
i have a question. i would like to clean objects in a tunnel.
for example object.jpg.
i now made a cross section and i am now able to cut out the building.
but afterwards i want to make a mesh over the complete tunnel. but i now just can cut out the building in the cross section.
is there a way i can cut out this building without a cross section ?
clean points in a tunnel / e57 geoslam scanner
- object.JPG (121.69 KiB) Viewed 2073 times
Re: clean points in a tunnel / e57 geoslam scanner
What does the cloud in your snapshot look like from behind? Do you see the 'ground' or do you see the empty building from behind?
If it's more like a closed shell, then you can use the 'PCV' plugin to compute the 'illumination' of points (see https://www.cloudcompare.org/doc/wiki/i ... s_(plugin)). This will give you a scalar field that you can use to filter out the darkest points (= the points inside the tunnel).
