SOFTWARE IS NOT RESPONDING
Posted: Thu Oct 17, 2019 1:45 pm
by nishitachhipa
I am trying to upload Dense point cloud of area 200sqkm but the software is 'Not Responding'. is there any limit regarding the size of land the software the work on. my point cloud is collected by using an arial UAV system through photogrammetry.
Re: SOFTWARE IS NOT RESPONDING
Posted: Thu Oct 17, 2019 8:28 pm
It all depends on your computer's memory, and maybe also on your graphic card (if you want to interact with a huge number of points).
Do you know the number of points?
Posted: Fri Oct 18, 2019 1:49 pm
by nishitachhipa
RAM - 32GB and GPU RTX 2060.
CAN WE PROCESS THIS DENSE POINT CLOUD ON THE NETWORK OF PCS?
WE HAVE THREE PC WITH SAME CONFIGURATION.
Posted: Fri Oct 18, 2019 7:55 pm
Ah sadly no ;)
I know that people were able to process clouds up to 1 billion point. But above that, I wouldn't expect too much from CloudCompare (especially since it has a theoretical limit of 2 billion points per cloud).
Posted: Wed Oct 23, 2019 4:24 pm
by Flanker_27
That cloud must be huge, I was taught to use CC at work by a colleague with a computer whiich has a similar configuration, and he worked without any real issue with an 1.2 billion point model this summer.
