Saving in CC registered scans from Recap
Darius_bd
Post by Darius_bd »
Hi!
I'm a bit lost as I feel I'm doing something basically wrong but I couldn't find the answer in the forums or in CC's options.
So, I registered a bunch of cloud scans in Recap, and then exported in E57. Then I opened it in CC and resaved it without doing anything else. Then I noticed that all the scans had the same origin shared between them, whereas when opening the exported E57 from Recap shows that each scan has their origin at the sensor's coords.
Is there a way to save in E57 a bunch of registered scans without CC moving the original origin of each scan?
Hopefully is understandable the problem I have? Otherwise I'm happy to provide more detailed info.
Re: Saving in CC registered scans from Recap
Which version did you use? I believe the capacity to restore the sensor origin is a recent addition of the latest 2.11.alpha.
Darius_bd
Post by Darius_bd »
Well, 2.10. I'll try it with 2.11 alpha and report back ;)
Darius_bd
Post by Darius_bd »
It works!
Excellent, many many thanks for your continuous and amazing work!
