Cross Section in Console problem
Iga
Post by Iga »
I try to run the cross secrion feature in console but whatever i try to do i get the same message
that console cannot open the xml file. Path is correct, I downloaded the example xml from the site and also created output folder in C:\data\output in order the leave the XML file intact.
Nothing works, console always stops at the xml file.
Tried to run the xml from different locations, same thing happens and everything stops.
Paths are all in latin characters.
Any ideas?
Thank you.
Re: Cross Section in Console problem
What's the message exactly? And which version are you using?
Iga
Post by Iga »
Hello, I used v. 2.10.2 and 2.11 alpha.
Please see the image attached.
Why do you have brackets ({}) around the filename?
Iga
Post by Iga »
: Ο
It was that simple ! Thank you ! :D
It was unclear for me that part.
Thanks again, all ok now.
