Rotation about Z-only during Align by Points Picking
lmcbean
Post by lmcbean »
Hello all,
I almost always align my clouds to provided control points/targets using Align (Points Picking). However, sometimes my control coordinates are less than perfect. In such cases, I want to hold my Z-axis vertical, and do a best fit to 4 or more points. In the Translate/Rotate function, I can manually do this by selecting Z as the axis about which to rotate. My vertical remains vertical. When I do the same thing in the Align tool, my Errors go from something like 0.02m with a three-axis rotation, to something like 750m or more for a Z-only rotation. Ideally, the 3-axis (x,y,z) should fit control best, and I generally leave this on. However, when the control is not great, this can allow the Z-axis to be rotated more than I want.
Has anyone else had this problem?
Thanks,
Laurie
Re: Rotation about Z-only during Align by Points Picking
It would be good for me to have an example of dataset (and control points) so as to reproduce the issue. Can you send it to me? (admin [at] cloudcompare.org)
