Command Line PCV
Posted: Sat Aug 10, 2019 8:23 am
I am running Linux 2.10.1 Zephyrus; the Command Line wiki lists -PCV {params} as a command line option, but it doesn't seem to be working.
Is this a working function and I'm just not calling it right? Or is it not working?
I am familiar with Command Line operation, for example, here is a command line I use frequently, and successfully.
cloudcompare.CloudCompare -AUTO_SAVE OFF -NO_TIMESTAMP -LOG_FILE /home/ubuntu/Desktop/CClog.txt -O /home/ubuntu/Desktop/recordings/COEX_lobby_replay/pointcloud_COEX_lobby_replay_N_r.ply -C_EXPORT_FMT PLY -PLY_EXPORT_FMT ASCII -SET_ACTIVE_SF 2 -FILTER_SF 0 40 -SOR 25 0.05 -SS SPATIAL 0.005 -SF_COLOR_SCALE /home/ubuntu/Desktop/scales/intensity -SF_CONVERT_TO_RGB FALSE -SAVE_CLOUDS FILE /home/ubuntu/Desktop/recordings/COEX_lobby_replay/pointcloud_COEX_lobby_replay_N_r_out.2.ply
I would like to include a -PCV in this command line right after the application of the intensity colors. I know how to insert the command, but CloudCompare exits with error when it reaches the -PCV directive.
Any ideas on what the problem is?
Wade Sheen
Kaarta
Wade Sheen
Kaarta
