Surface centroid how to shift?
Posted: Sat May 11, 2019 11:34 pm
by mbmiller34
How do I shift the Surface Centroid in CloudCompare? I assumed the box center was the same but it is not. Any suggestions?
I need to make the surface centroid on two different models match exactly. Shifting the box center brings it close but not close enough.
Can I display the surface centroid coordinates in CC? I can only see them with a different program
Re: Surface centroid how to shift?
Posted: Sun May 12, 2019 6:48 pm
What do you call the surface 'centroid'? Is it the gravity center? (then no, there's no way to display it). However if you compute them, you can the use the 'Edit > Apply translation' tool to make them match).
Posted: Wed May 15, 2019 5:09 am
by mbmiller34
3D Reshaper displays the surface centroid coordinates which are different than the center box coordinates displayed in CC
Posted: Wed May 15, 2019 7:40 pm
Then I guess it's not the bounding-box center :p
