M3C2 Core point params.txt issue
Posted: Sun Mar 10, 2019 11:55 pm
by pmdifran
I have encountered an issue with importing a M3C2_params.txt file into the M3C2 plugin. The M3C2_params.txt file is not storing the core point selection settings (i.e use cloud #1, subsample, or use other cloud).
As a result, when running m3c2 from command line it reverts to subsampling (even if I select "SubsampleEnabled =false in the parameters file). I am trying to batch m3c2 change using cloud#1 for core points each time.
Thanks,
Paul-Mark
Re: M3C2 Core point params.txt issue
Posted: Tue Mar 12, 2019 5:36 am
Thanks for the feedback. I guess we must fix that asap ;)
