Where to find the maximal error after C2C or C2M analysis
Posted: Thu Jan 17, 2019 8:37 am
by pochihlee
Hi All,
I would like to know how to find out where the maximal error located in my model after I compare two objects using C2C or C2M methods.
After the comparison, the color on the object can only roughly tell us the errors on it. However, if I want to the exact location that the maximal error happens, what should I do?
Thank you for the reply.
Po
Re: Where to find the maximal error after C2C or C2M analysis
Posted: Thu Jan 17, 2019 8:44 pm
You can play with the minimum displayed (distance) value of the active distance scalar field so as to visually isolate it:
Alternatively you can use the 'Edit > Scalar field > Filter by value' tool to extract the point with the maximum distance.
