DB Tree Maximum point clouds
fblue
Post by fblue »
How many point clouds (or files) maximum can we charge in DB Tree in V2.9.1?
In the doc(2.6.1) it is said that we can get up to 150 millions points for reasonable frame rate. Is '150 millions points' for just the point cloud openning in display window or for all the point clouds charged in DB tree?
Re: DB Tree Maximum point clouds
Actually, it depends on the graphic card (with modern GPUs such as the GeForce 1080, I can work with 500 M. points and still get a decent frame rate). And with the modern version of CC (2.9 and later), you also have the LOD mechanism that will help a lot.
Anyway, it's the total amount of displayed point that matters (which can be different from the number of loaded points). So 150 to 500 M. points in total.
