Primitive factory - Cylinders
Posted: Fri Aug 17, 2018 8:51 am
by westergu
Is there a smart way how to add multiple CloudComare Cylinders (object) from at text file? For example in a format like this
X1 Y1 Z1 X2 Y2 Z2 RADIUS
From Primite factory you can only insert one cylinder at a time (as I have understand) and the orientation of the cylinder has to be modified via the "Apply transformation" tool. This is rather time consuming if you have to insert tens of cylinders.
Thank you btw for a wonderfull tool!
Best regards!
Gustav
Re: Primitive factory - Cylinders
Posted: Sun Aug 19, 2018 4:36 pm
Nope, there's no way currently to import cylinders or other primitives (apart from the PDMS .mac script format which is not easy to generate).
