Calculate rockfall volume from 3D point clouds
Posted: Tue Jul 24, 2018 5:06 pm
I have 2 TLS point clouds and have used the M3C2 plugin to identify areas of significant change (i.e. rockfalls, see attached figure - significant change in grey). I would like to isolate individual rockfalls and calculate the volume for each. The image attached is just a small section of the cliff face.
I have tried the 2.5D volume calculation but I am not sure if I am doing it correctly. Its very difficult to draw an exact polygon around each rockfall so I extract the the area of change identified by the M3C2 plugin for each point cloud by selecting both clouds (normals),drawing a box around the area of change and extracting.I then select both extracted areas and open the 2.5D volume tool. The settings used are shown in attachment and result below.
Volume: -0.063
Surface: 1.259
Added volume: (+)0.022
Removed volume: (-)0.085
Matching cells: 93.1%
Non-matching cells:
ground = 1.5%
ceil = 5.5%
Average neighbors per cell: 7.9 / 8.0
Re the surface area - is this the entire planar or entire 2.5D surface area I extracted? or is it the planar or 2.5D surface area of change only? Should I only select the exact area of change?
Re the volume calculations - is there any way to determine the error on this value? It's a vertical cliff face so in theory there should not be any added volume only loss, hence I'm slightly concerned about getting added volume in the results. Perhaps this can be used to estimate an error term?
Finally, I have hundreds of rockfalls to calculate volume on is there any way to automatically select them? I have seen on other posts about connected components but I am still not clear on how it works.
Thank you in advance for any help on this,
Niamh
Volume: -0.063
Surface: 1.259
Non-matching cells:
ground = 1.5%
ceil = 5.5%
Niamh
