Invisible folder + problem at launch
Posted: Tue May 22, 2018 8:59 am
Sorry in advance if this problem has already been mentioned, but I can't find anything about it neither on the forum nor on google.
I've just downloaded CloudCompare using snap on linux, with :
It seems to be working fine, though I do have some error messages when launching :
My problem is I can't seem to see some folders on the File>Open window, one named "localstorage" for instance, located at the root. It is supposedly not a permission problem because I have all (read, write, execute) of them. Another directory, at the same location with similar privileges, named "tmp", is properly seen.
Furthermore, when I go in this directory and try top open in command line a .laz file :
I get the error :
but this file does exist, and has not particular characters. When I copy it to a visible folder, it is clearly seen (though I can't open it for compression issue, but that's another problem...).
Would you have an idea why this is happening?
Best regards.
EDIT : actually the folder tmp is visible, but anything that's inside it is invisible. Going inside an "invisible folder" from a browser outside CloudCompare, I tried to drag an d drop a file to CloudCompare, it also tells me the file does not exist.
EDIT2 : Converting my laz files to las format fixed the other issue of not being able to open laz files
snap install cloudcompareCode: Select all
/bin/bash: warning: setlocale: LC_ALL: cannot change locale (en_US.UTF-8)
Qt: Session management error: Authentication Rejected, reason : None of the authentication protocols specified are supported and host-based authentication failedFurthermore, when I go in this directory and try top open in command line a .laz file :
cloudcompare -O file.lazCode: Select all
[Load] File '2010215_Helimap_SFM_M.laz' doesn't exist!Would you have an idea why this is happening?
Best regards.
