section Extraction about polyline
Any question about the database & algorithms library 'CCLib'
kasper
Post by kasper »
now i have a pointcloud ,and i want to input two points data to extract the polyline of it.
i found that in ccSectionExtractionTool.cpp ,there is a function named "ccSectionExtractionTool::extractPoints()"
but i dont really understand what is i need to use in my code.
is anyone know how to achieve my goal? any step tutorial, example or help.
its a big problem to me ..... thanks
Re: section Extraction about polyline
Not sure to understand: do you simply want to connect two points by a line? (then you should simply create a ccPolyline instance) or do you want to extract the points that are close to a segment? (in this case, you still have to create a polyline instance, but then you have to call the segmentation algorithm from CCLib if I'm not mistaken.
kasper
Post by kasper »
Got it , thanks Daniel
