qCompass - Trace Tool
Posted: Sat Mar 24, 2018 8:21 pm
by 12olc
I'm looking to map some joints and am trying to use the trace tool in the Compass plugin. Once I trace and accept the feature I can't seen to find where the orientation of the new plane is or how to export them.
Sorry for the novice question, I'm new to the program.
Thank you!
Re: qCompass - Trace Tool
Posted: Sun Mar 25, 2018 10:59 pm
by SamThiele
Hi 12olc,
Compass doesn't fit-planes to traces by default, as this can get annoying when tracing things like contacts (that might not be planar). To make the plugin fit a plane you need to either:
(1) Press "Shift+Enter" rather than "Enter" when accepting the trace, or;
(2) Activate "Fit Planes" in the trace menu (next to the undo button).
Once a fit-planes has been computed it should appear in the DB Tree as a Plane object who's name gives the dip and dip-direction. After you've finished digitizing your joints, you can then export all the planes in the workspace to a friendly .csv format using the export button in Compass (save icon).
Finally, it is worth noting that Compass will refuse to fit a plane to a trace that is close to co-linear (as this can give very misleading results). When this happens a warning will appear in the console - though if you are certain that you want to compute a best fit plane then you can select the trace and fit a plane using Edit->Plane->Fit. Just beware that the trace may not contain enough 3D information to actually constrain the 3D orientation of your structure!
Hope this helps,
Sam
Posted: Mon Mar 26, 2018 12:05 am
by 12olc
That's exactly what I was looking for, Thanks Sam!
