CloudCompare freeze when Subsample by active coordinate Scalar Field
Jacoban90
Post by Jacoban90 »
Hi CloudCompare Community:
I recently discovered the program by another user and I found it very practice.
My question is related to the subsample tool. My objective is to modulate the distance between points by using a coordinate scalar field, concretally in the z direction. When I go to edit;subsample;go to space mode and check "Use active scalar field". maximum and minimum space. and press "Ok", the program freezes.
Thank you all in advance
Best Regards
Jacob
Re: CloudCompare freeze when Subsample by active coordinate Scalar Field
Which version are you using? Moreover, make sure to use 'realistic' values, as if the radius become very big for some values it may take a long time to process.
Jacoban90
Post by Jacoban90 »
I'm using the 2.9.1 version. I proved with diferent distances but it doesnt change nothing.
I attach you below the link with the .stl mesh and the cloudcompare file with the attachment. I cannot upload directly to thew forum. I dont know why.
https://drive.google.com/open?id=14EmZK ... k09oKJIgHu
https://drive.google.com/open?id=19bPKj ... AtjTXVNj_D
Best Regards
Jacob
Well, I'm not sure what you are trying to achieve with a mesh (in "Cloud"Compare ;). However I assumed you were trying to resample the vertices?
Here's what I got (after setting the Z coordinate as scalar field):
It works fine on my side. And it works also if I do this on a sampled version of the mesh (plane).
Jacoban90
Post by Jacoban90 »
Yes, I created the mesh in another program. Then I imported in cloudcompare to extract the vertices.
I defined a active scalar field to the z coordinate.
https://drive.google.com/open?id=1JgVJn ... jR7Un0whtT
I created the subsample using the "z scalar field" at the same way of you.
https://drive.google.com/open?id=1e_GhZ ... dgKKfBlQg3
But when I press ok the program freezes and doesn´t seem to work.
https://drive.google.com/open?id=19e15o ... ipeMJv8f8E
Best Regards
Jacob
Can you try with the 2.10.alpha version then?
Jacoban90
Post by Jacoban90 »
Perfect the problem was related to the version of the program. In 2.1 works fine. Thank you very much.
Best Regards
Jacob
