Xeon processors only using 1/8 of there capabilities
WimLouis
Post by WimLouis »
I was wondering if there is a way to get more preformance out of CC
using a machine with 2 Xeon processors.
but for a comparison of 2 clouds the machine is only using 1/8 of the CPU
no other programs are running
is there a way to boost CC's CPU usage?
Re: Xeon processors only using 1/8 of there capabilities
Which version are you using? With the latest you can choose the number of 'threads' used.
By default CC should take all available 'cores' (at least as it is managed by Qt, the library CC is built upon). Maybe Xeon processors are not correctly handled?
Dimitri
Post by Dimitri »
I have dual-xeon workstation (2 years old version) under windows 7, and CC systematically uses all the threads (28) available when it can, and has been doing so for quite some time.
Are you under Linux ?
