Need help selecting points behind objects for point cloud alignment
Posted: Wed Aug 30, 2017 4:24 pm
Hi guys !
I am having a little problem. I have 3 rooms I need to register or align together, they all share sight lines etc.
the problem I am having is that because these are rooms with 4 walls and a ceiling, I am unable to pick the point I need to pick.
I thought that by using the segmentation tools or sections I would be able to get to where I need. But the issue is that if sections all 3 rooms to be able to pick point or features on the floor for example, then I am aligning the sectioned point clouds and not the entire dataset.
Can someone please help me with this workflow?
Thank you
Thank you
