Ubuntu Server
Posted: Fri Jun 09, 2017 3:21 pm
HI,
I'm trying to run CC for batch conversions on a remote Linux Server(Ubuntu 14.04). Every time I try to run CC in the command line I get
"CloudCompare: cannot connect to X server."
The command I'm using is
"CloudCompare -SILENT -O test.las -M_EXPORT_FMT OBJ -DELAUNAY"
If I ssh into the machine with X11 forwarding I don't get a error but the code doesn't generate an output. I have tested the command on a local linux box running 16.04 and it generates expected output. Does anyone know what may be the cause of this, any help would be greatly appreciated.
Regards,
Dáire
Regards,
Dáire
