Global shift/scale
Haowyr
Global shift/scale
Post by Haowyr »
Hello guys :)
I'm working on a pretty large project, so I need to use the "scale" function to open my files together. So here come two questions:
- Why, whenever I create a new line in the "global_shift_list.txt", it appears in the list but the function "Yes to All" doesn't, I have to click for every single file
- Is there any way to apply the same type of scale in the command line mode?
Thanks guys
Re: Global shift/scale
The 'global scale' feature is clearly not as well supported as the 'global shift' one. Mainly because of a lack of testing and user feedback.
I'll see if the 'Yes to All' option is grayed out for a reason. And for the global scale option via the command line, I guess we must add the option as it has never been requested before (afaik).
Haowyr
Post by Haowyr »
Ok thanks Daniel, and for now, I found another solution, using csv files and reduucing the number of file needed, so I basically did it manually ;)
