changing default units Adjusting Scalar Field Params.
Posted: Thu Jan 26, 2017 6:28 pm
It is difficult to interpret the default units and would like to shift them to read in standard inches measurements and visualize them on screen display and any output.
Scalar Field Display Range Parameters & Units
I would like to adjust the scalar field to display fewer color levels and to display in inch units and adjust the scale to read any deviation outside 7/8th of an inch.
I would like to create a color ramp that lists 0 and has an increase and decrease of 1/8, ¼, 3/8… on up to a few inches. I would like to make the numbers appear in inch or a percentage of an inch or legible in this unit. I would like it to display these figures (unit figures) on the Scalar Field scale bar. Is it possible to assign a color to 1/8”? When I adjust, the Colors setting, from RGB to Scalar Field, the colors change and the Scalar Field bar disappears. The color map also changes. It would be nice to use the RGB and retain the Scalar Filed menu. I am not sure how to use this option and have a scale bar show the data on screen.
