wierd problem with command -LOG_FILE {filename}
Posted: Thu Nov 24, 2016 2:24 pm
I am facing some weird problem in command line mode.
this is what I run in a batch fileand I get this output in text file as expected
[14:53:26] Auto-save is enabled
[14:53:26] [LOADING]
[14:53:26] Opening file: 'smallA.las'
[14:53:26] [LAS] smallA.las - signature: LASF
[14:53:26] [LAS] Cloud has been recentered! Translation: (-3409533.30,-5478490.66,-296.84)
[14:53:26] [LAS] Color field was all black! We ignored it...
[14:53:26] [LAS] All 'Point Source ID' values were the same (0)! We ignored them...
[14:53:26] [LAS] All 'Flightline Edge' values were the same (0)! We ignored them...
[14:53:26] [LAS] All 'Scan Direction' values were the same (0)! We ignored them...
[14:53:26] [LAS] All 'Return Number' values were the same (0)! We ignored them...
[14:53:26] [LAS] All 'Time' values were the same (0)! We ignored them...
[14:53:26] [LAS] All 'Classification' values were the same (0)! We ignored them...
[14:53:26] [I/O] File 'smallA.las' loaded successfully
[14:53:26] Found one cloud with 26546 points
[14:53:26] Opening file: 'smallB.las'
[14:53:26] [LAS] smallB.las - signature: LASF
[14:53:26] [LAS] Cloud has been recentered! Translation: (-3409533.28,-5478490.67,-296.84)
[14:53:26] [I/O] File 'smallB.las' loaded successfully
[14:53:26] Found one cloud with 27228 points
[14:53:26] Processed finished in 0.12 s.
but when I run same command with big clouds(out of which above clouds are segmented),I get log of only last command .i.e -o bigB.las:
[14:52:27] [LAS] All 'Point Source ID' values were the same (0)! We ignored them...
[14:52:27] [LAS] All 'Flightline Edge' values were the same (0)! We ignored them...
[14:52:27] [LAS] All 'Scan Direction' values were the same (0)! We ignored them...
[14:52:27] [LAS] All 'Return Number' values were the same (0)! We ignored them...
[14:52:27] [LAS] All 'Classification' values were the same (0)! We ignored them...
[14:52:27] [I/O] File 'bigB.las' loaded successfully
[14:52:27] Found one cloud with 4712960 points
[14:52:27] Processed finished in 6.40 s.
If I add -C2C_DIST command with big data files, I get log of C2C_DIST only :
[14:46:49] [I/O] File './bigA_C2C_DIST_2016-11-24_14h46_45.bin' saved successfully
[14:46:49] Processed finished in 39.91 s.
@ECHO ON
CloudCompare -AUTO_SAVE ON -o smallA.las -o smallB.las -LOG_FILE smalllaslog.txt[14:53:26] Auto-save is enabled
@ECHO ON
CloudCompare -AUTO_SAVE ON -o bigA.las -o bigB.las -LOG_FILE biglaslog.txt [14:52:27] [LAS] All 'Point Source ID' values were the same (0)! We ignored them...
@ECHO ON
CloudCompare -AUTO_SAVE ON -o bigA.las -o bigB.las -C2C_DIST -LOG_FILE biglaslog.txt[14:46:49] [I/O] File './bigA_C2C_DIST_2016-11-24_14h46_45.bin' saved successfully
