Extract points using several polygons
Nico
Post by Nico »
Hi CC community,
My question is, how can I extract points from a point cloud using several polygons at the same time? By using the segment tool I can select just one polygon at a time.
Re: Extract points using several polygons
Indeed, you can only use one polyline at a time for now.
Another option would be to use the command line tool (see the CROP_2D option: http://www.cloudcompare.org/doc/wiki/in ... _line_mode) with a script.
Nico
Post by Nico »
Thanks Daniel :)
