Command Line - Cross Section - Extract Polyline
Posted: Mon Sep 19, 2016 2:52 pm
by orso
I am writing to see if the command line tool will extract a polyline with each generated cross section (In the same way the GUI tool functions). Similar to page 4 of the following document: http://www.cloudcompare.org/doc/qCC/Clo ... ool_V2.pdf.
If no, is this on your roadmap?
Thanks for the support!
orso
Re: Command Line - Cross Section - Extract Polyline
Posted: Mon Sep 19, 2016 7:59 pm
Nope, you can only automate the slices extraction from now (but not the contour extraction from these slices).
Posted: Sat Sep 24, 2016 2:34 am
by orso
Thank you for letting me know.
Daniel,
One more question:
Is it possible, through the command line, to extract a single polyline for a set of points? If no, is this on your roadmap?
Thank you for all of your continued support!
Posted: Sat Sep 24, 2016 1:23 pm
Not particularly... I can of course add it to the TODO list, but considering how big it is already it might take a lot of time before it's available ;)
Posted: Sat Sep 24, 2016 2:33 pm
by orso
That would be great! Just donated for this great piece of software. Struggling to pay off student loans and such, so could only afford $10. Will add more if I can. Thanks, again for the continued support!! ;)
Posted: Sat Sep 24, 2016 5:15 pm
by orso
Daniel:
Are you using a pcl tool for extracting a best fit contour line. If so, would you point out which tool in pcl does this? I am wondering if I can build a standalone app that reads in a sliced point cloud from cloud compare, then exports the best fit polyline.
Thanks for the continued support!
Posted: Sat Sep 24, 2016 5:28 pm
Nope, it's CC's own code.
We don't use PCL apart in the qPCL plugin.
Posted: Thu Jun 08, 2017 6:54 am
by ivan-zd
I don't want to open another topic just for this so I hope you would see it here. Are there any news about this functionality?
I am also looking for a way to extract a best fit contour line from a cross section output that i get throughthe command line.
Best regards,
Ivan
Posted: Thu Jun 08, 2017 9:06 am
As far as I know, nothing has been done in this direction.
