Problems with Headers? when exporting ASCII or LAS File
khornsby
Post by khornsby »
The problem occurs when I try and save the aligned balloon point cloud as an las file or an ascii file to build a DEM out of in LAStools or Arc. The headers seem to get messed up and neither LAStools software nor ArcGIS can build a DEM. Do you know how to make CloudCompare lock headers? Or an alternative solution to this? The files show a header with XYZ that only contain the X values.
Thanks,
Kris
Inline image 1
Re: Problems with Headers? when exporting ASCII or LAS File
Not sure to understand your issue.
Can you maybe send me a file with a wrong header? What version are you using by the way?
