Page 1 of 2
How to add texture information in "ccSphere" class?
Posted: Mon Jul 25, 2016 6:14 am
by Jame
Hello! I am a novice, I want to a picture of the aspect ratio of 2:1 to "ccSphere" class structure, according to the sphere of the medial do fake "ccPlane" class, add a "setAsTexture" method, why stick texture are displayed in the sphere of the outside rather than inside, thank you!
Re: How to add texture information in "ccSphere" class?
Posted: Mon Jul 25, 2016 7:20 am
Can you clarify your question? It's hard to understand...
Posted: Mon Jul 25, 2016 7:55 am
by Jame
daniel wrote:Can you clarify your question? It's hard to understand...
I am sorry,it is that I want to add texture in "ccSphere" class,now i add a "setAsTexture" function in "ccSphere" class like "ccPlane" class, and
rewrite the" buildUp" function. The question is that the texture is show abnormal and displayed in the sphere of the outside rather than inside.
The code is:
// Build up.
bool ccSphere::PanoBuildUp()
//[1]vertices
unsigned count = (g_iCol+1)*(g_iRow+1);
//[2]faces
unsigned faces = g_iCol*g_iRow*2;
if (!init(count,true,faces,0))
ccLog::Error("[ccSphere::buildUp] Not enough memory");
return false;
//[3] Initialize the ball coordinate matrix
float SpherePt[g_iCol+1][g_iRow+1][3];
int step_t = 360/g_iCol;
int step_f = 180/g_iRow;
for(int theta=0;theta<=360;theta+=step_t)
for( int fai=180;fai>=0;fai-=step_f)
SpherePt[theta/step_t][(180-fai)/step_f][0]=cos((float)theta/180.0*M_PI)*sin((float)fai/180.0*M_PI)*2;
SpherePt[theta/step_t][(180-fai)/step_f][1]=cos((float)fai/180.0*M_PI)*2;
SpherePt[theta/step_t][(180-fai)/step_f][2]=sin((float)fai/180.0*M_PI)*sin((float)theta/180.0*M_PI)*2;
//[4]vertices
ccPointCloud* verts = vertices();
assert(verts);
CCVector3 N,P;
for(int i=0; i<=g_iCol; ++i)
for (int j=0; j<=g_iRow; ++j)
N.x = SpherePt[i][j][0];
N.y = SpherePt[i][j][1];
N.z = SpherePt[i][j][2];
verts->addNorm(N);
P = N*m_radius;
verts->addPoint(P);
//[5]faces
assert(m_triVertIndexes);
for (int i=0; i<g_iCol; ++i)
for (int j=0; j<g_iRow; ++j)
unsigned A,B,C,D;
A = i*(g_iRow+1)+j; // Lower left corner
B = i*(g_iRow+1)+j+1; // The upper left corner
C = (i+1)*(g_iRow+1)+j+1; // Upper right corner
D = (i+1)*(g_iRow+1)+j; // Bottom right corner
addTriangle(A, C, B);
addTriangle(A, D, C);
notifyGeometryUpdate();
showNormals(true);
return true;
// load image texture.
bool ccSphere::setAsTexture(const QImage& image)
if (image.isNull())
ccLog::Warning("[ccSphere::setAsTexture] Invalid texture image!");
return false;
//texture coordinates
TextureCoordsContainer* texCoords = getTexCoordinatesTable();
if (!texCoords)
texCoords = new TextureCoordsContainer();
if (!texCoords->reserve(g_iCol*g_iRow*4))
//not enough memory
ccLog::Warning("[ccSphere::setAsTexture] Not enough memory!");
delete texCoords;
return false;
//[2] Texture image coordinate matrix
float ImagePt[g_iCol+1][g_iRow+1][2];
for(int i=0;i<(g_iCol+1);i++)
for(int j=0;j<(g_iRow+1);j++)
ImagePt[i][j][0]= (float)i/g_iCol; // X
ImagePt[i][j][1]= (float)j/g_iRow; // Y
//create default texture coordinates
float TA[2] = { 0.0f, 0.0f };
float TB[2] = { 0.0f, 1.0f };
float TC[2] = { 1.0f, 1.0f };
float TD[2] = { 1.0f, 0.0f };
for (int i=0;i<g_iCol;++i)
for (int j=0;j<g_iRow;++j)
TA[0]=ImagePt[i][j][0];
TA[1]=ImagePt[i][j][1];
TB[0]=ImagePt[i][j][0];
TB[1]=ImagePt[i][j+1][1];
TC[0]=ImagePt[i+1][j+1][0];
TC[1]=ImagePt[i+1][j+1][1];
TD[0]=ImagePt[i+1][j][0];
TD[1]=ImagePt[i][j][1];
texCoords->addElement(TA);
texCoords->addElement(TC);
texCoords->addElement(TB);
texCoords->addElement(TD);
setTexCoordinatesTable(texCoords);
if (!hasPerTriangleTexCoordIndexes())
if (!reservePerTriangleTexCoordIndexes())
//not enough memory
ccLog::Warning("[ccPlane::setAsTexture] Not enough memory!");
setTexCoordinatesTable(0);
removePerTriangleMtlIndexes();
return false;
//[3] set default texture indexes.
unsigned A,B,C,D;
A = i*(g_iRow)+j; // Lower left corner
B = i*(g_iRow)+j+1; // The upper left corner
C = (i+1)*(g_iRow)+j+1; // Upper right corner
D = (i+1)*(g_iRow)+j; // Bottom right corner
addTriangleTexCoordIndexes(A, C, B);
addTriangleTexCoordIndexes(A, D, C);
if (!hasPerTriangleMtlIndexes())
if (!reservePerTriangleMtlIndexes())
//not enough memory
removePerTriangleTexCoordIndexes();
return false;
//[3] set default material indexes
addTriangleMtlIndex(0);
//set material
if (!getMaterialSet())
setMaterialSet(new ccMaterialSet());
ccMaterialSet* materialSet = const_cast<ccMaterialSet*>(getMaterialSet());
assert(materialSet);
//remove old material (if any)
materialSet->clear();
//add new material
ccMaterial::Shared material(new ccMaterial("texture"));
material->setTexture(image,QString(),false);
materialSet->addMaterial(material);
showMaterials(true);
return true;
Posted: Mon Jul 25, 2016 8:02 am
by Jame
The aspect ratio of the picture is 2: 1, just like the attach file:"image1.jpg".Thanks very much!
Posted: Mon Jul 25, 2016 8:11 am
I can't see the image. It would be very helpful ;)
Posted: Mon Jul 25, 2016 8:13 am
Oh, and can you show us a snapshot of the current result?
Posted: Mon Jul 25, 2016 8:29 am
by Jame
daniel wrote:Oh, and can you show us a snapshot of the current result?
Ok! The snapshot of the current result like attach file "snapshot.jpg", I user "ccViewer" to display:
Besides the variable “g_iCol” and "g_iRow" is:
const int g_iCol=90;//Setting the image many times do longitudinal split
const int g_iRow=45;//Setting the image many times do lateral split
Posted: Mon Jul 25, 2016 8:32 am
by Jame
daniel wrote:I can't see the image. It would be very helpful ;)
Can't you see the image? I added it by the "Add files" button of "Attachement". ...
Posted: Mon Jul 25, 2016 8:53 am
Can you see it?
Once you select it, check that the 'status' is a green check symbol. And just to be sure, click on 'place inline' (with the cursor at end of your message for instance).
Posted: Mon Jul 25, 2016 8:55 am
by Jame
"image1.jpg":
The snapshot of the result:
"snapshot.jpg"
