smoothing and adjusting set of point cloud
Posted: Thu Jul 14, 2016 9:05 am
by Jacob_C
I would advise you to certain issue. I need to make an inventory of road using point clouds aquired by my drone. To processing my data I have to remove noisy scattered data points and get smoothed set of points in order to prepare proper point cloud to further process. As the result I need to reconstruct surface that is the best adjusted and approximated to the real road surface.
I have read about Moving Least Squares (MLS) surface reconstruction. It looks great but I have a doubt it distorts the model of the surface. Always when I use this method the final surface is slightly below the whole point cloud. But I need to adjust my surface to agglomeration of points (exclude noisy points).
I am attaching a image of example points to submit what I mean.
Thank you for any suggestion in this case.
Best wishes,
Jacob
zrzut (Kopiowanie).jpg (60.13 KiB) Viewed 12603 times
Re: smoothing and adjusting set of point cloud
Posted: Sat Jul 16, 2016 2:07 pm
Hi Jacob,
Sadly I don't know much about the MLS function. It's part of the qPCL plugin and therefore it's only a portage of the PCL "MLS" functions (see http://pointclouds.org/documentation/tu ... mpling.php).
Luca Penasa (the author of the plugin) may be able to give you more info about it. Or the PCL community more probably.
Posted: Thu Oct 13, 2016 8:29 am
by muzo583
You can try SOR (Statistical outlier removal) before MLS algorithm that would improve the quality of the surface.
