Camera/sensor poses. How do you set them in CC?
pushrbx
Post by pushrbx »
I'd like to use CC to create a fly through animation on a point cloud based on a text file which has rows in the following format:
Timestamp x y z roll pitch yaw
Example:
1448534152426583, 0.000016373800, 0.000000496031, -0.000051859500, 0.000006510990, -0.000002266520, -0.000000595645
1448534152476580, 0.000002952982, 0.000008420957, -0.000129863979, 0.000010835746, -0.000003999963, 0.000001385994
1448534152526579, -0.000012847086, -0.000019797941, -0.000178220648, 0.000006050605, -0.000007709890, 0.000003889104
1448534152576577, 0.000055242237, -0.000024177319, -0.000153043349, 0.000001814640, -0.000015749586, 0.000009759885
1448534152626574, -0.000150767281, -0.000008456334, -0.000701345565, 0.000004704640, -0.000109008891, 0.000012938696
1448534152676572, -0.000142334592, 0.000007828226, -0.000690973969, 0.000011021827, -0.000116716296, 0.000013978659
1448534152726570, -0.000012580036, 0.000089568445, -0.000791200925, 0.000033929342, -0.000148412948, 0.000009564050
1448534152776568, -0.000035494673, 0.000095962351, -0.000772499808, 0.000031521704, -0.000143479440, 0.000008744500
I already know that if I'd like to accomplish such a functionality I have to write a plugin. But before I do that I'd like to test these values. To test them I assumed I have to use the "Edit -> Sensors -> TLS/GBL -> Create" menu poiint, but I don't know how to input these values in the Sensor parameters window. How does this data fit in that form?
Do I have to transpose/transform these values into a 4x4 matrix?
Re: Camera/sensor poses. How do you set them in CC?
If you really want to create an animation then you should create either 'projective camera' entities or 'viewport' entities.
The later will even let you use the qAnimation plugin. In which case you would only need to create a bunch of 'cc2DViewportObject' objects when loading your file. This could even be done quite easily in a 'I/O' plugin (look at the 'qCSVMatrixIO' plugin for an example - you don't even need a dialog in your case, or maybe just one to set the missing parameters such as the field of view).
You can leave some parameters of the viewport objects (see ccViewportParameters) to their default values, but be sure to force:
perspectiveView = true
objectCenteredView = false
cameraCenter = (x y z)
And last but not least, to create the viewing matrix (viewMat) from the 'roll pitch yaw' parameters, you can follow these guidelines:
http://www.songho.ca/opengl/gl_anglestoaxes.html
The rotation matrix (3 x 3) is the upper left part of the (4 x 4) viewMat matrix. Leave the other values to their default (i.e. zeros everywhere but the last diagonal element which should be 1).
Don't hesitate to ask for more directions.
pushrbx
Post by pushrbx »
Thanks for your reply daniel. This OpenGL information was really missing for me.
Please correct me if I'm wrong:
So I have to take the x y z roll pitch yaw values from a row in my text file and make it to a 4x4 matrix.
For the conversion I have a matlab function:
 	function T = vector6_to_mat4x4(v)
 		T = zeros(4);
 		cr = cos(v(4)); cp = cos(v(5)); cq = cos(v(6));
 		sr = sin(v(4)); sp = sin(v(5)); sq = sin(v(6));
 		T(1,1) = cp*cq; T(1,2) = -cr*sq+sr*sp*cq; T(1,3) = sr*sq+cr*sp*cq;
 		T(2,1) = cp*sq; T(2,2) = cr*cq+sr*sp*sq; T(2,3) = -sr*cq+cr*sp*sq;
 		T(3,1) = -sp; T(3,2) = sr*cp; T(3,3) = cr*cp;
 		T(1,4) = v(1); T(2,4) = v(2); T(3,4) = v(3); T(4,4) = 1.0;
Then take this 4x4 matrix and convert it to a 3x3 matrix based on what you said and the link you have provided. Am I right?
Oh, your matlab code does pretty much the same job as the link I sent you. You already have your 'viewMat' matrix here (which is a 4x4 matrix). Maybe you will have to invert it afterwards (there's an 'invert' method on the ccGLMarix class) but you'll have to actually test it to realize that ;)
And it's better to remove the translation from the 'viewMat' matrix (the 'T(1,4) = v(1); T(2,4) = v(2); T(3,4) = v(3);' part) and set it as 'cameraCenter' (if you use a viewport object). But that's not mandatory.
