Autodesk Recap and compared cloud result
Posted: Tue Mar 15, 2016 12:49 pm
I am having a bit of problem with opening my file on Autodesk Recap. I used the tutorials provided on the website as guideline when carrying out the comparison on my clouds/mesh. After carrying out the comparison, I saved the file as an ASCII file, which I believe can be opened on Autodesk Recap. However, when the file is opened in Recap, the model opens with no colour (either grayscale or black), and when I change from RGB to Intensity on recap it changes the colour to red. I have tried to play around a bit with some of the setting but none has been successful.
I have also tried to set unique/colorize the clouds and even converting the scarlar field to RGB but it still comes out as grayscale or black on Recap.
Slightly confused now and not sure what else to do to get the file to open in Recap
Help :)
Help :)
