Registration of selected area?
Posted: Thu Oct 15, 2015 4:05 am
Is there a way to region/poly select the overlap area for registration?
The cloud points are taken from different angles I have varying degrees of success with existing methods. I might just be doing it wrong. So any suggestions for workflow I'll take.
This is what I currently do.
-Load ptx A, pick 3 points, level (although my ground is not actually level)
-Load ptx B, pick 3 points, level (although my ground is not actually level)
So I have A and B, but they are not actually level to each other (each scan has ~5million points).
-I then try to "finely register already ..."
(btw as a new user, data and model are ambiguous terms. please consider renaming/adding "moving" and "staying" to description)
-I try to guess what my "final overlap" percentage is
(if you get this wrong it will sometimes compute overnight, perhaps a give up after x minutes is needed? So many times I have to kill cloudcompare in task manager and try again)
-Often this will give me a good angle adjustment so I can then move it up/down.
-Other times it will be very very wrong and I have to try "align by picking point pairs", but my point pairs are not uniformly scaled between scans and I just have to eye-ball it.
I have 27 scans with a total of ~108 million points, I need them to be aligned perfectly through computation and not by me by hand. Any suggestions would be greatly appreciated.
I am re-assembling an outdoor scan of various degrees of overlap.
Scan A
Scan B
Scan A and B
Overlap area between A and B. I wish there was a way to finely register two clouds but only considering points in this area.
Scan A
Scan B
Scan A and B
