I scanned a flat surface with a microepsilon laser line scanner. Due to mechanical constraints the scanner was rotating above the surface instead of translating.
As a result, my cloud is not flat but slightly curved. I would like to make it flat.
I fitted a 2.5 quadric to the cloud and obtained
[14:59:23] [doActionFitQuadric] Quadric equation: z = 0.191051 + 3.54919e-05 * x + 0.0012838 * y + -0.00411161 * x^2 + 0.00332096 * x.y + -0.000473921 * y^2
Thank you for your support
