PTS file format specifications
Posted: Fri Jul 10, 2015 12:52 pm
Hello:
I know this question is not directly related with CloudCompare, but could be interesting for people interesting in TLS measurements. I'm working with PTS files, exported by Faro Scene software (also observed with a Faro TLS), and I'm confused about the format. I know the first line contains the total number of points and all remainder lines stores X Y Z intensity R G B. My problem is related to the 'intensity' column. I can't find any document where the PTS format is explained, so I confused with the intensity values limits. I've read in some forums that the intensity values take a range between -2048 to 2047, but in other places I've read that the limits are -4096 to 4095. Also, here (viewtopic.php?f=9&t=1281&hilit=pts) a user puts an example where intensities are up to 7500. Or maybe each software (Scene, Cyclone, etc.) has its own criteria?
First of all, which is the meaning of such values? I think the upper limit means 100% of relative emitted intensity signal, and lower limit means 0% intensity, i. e. there is not received signal. Am I right? Another question is about the true limits. Anybody knows them? Anybody knows where is (if exist) the official PTS file format specifications document?
