[FIXED] Surface of Revolution Analysis failed to export dxf
SarunasBand
Post by SarunasBand »
first of all, thanks to Daniel for the awesome software, great job!
Now back to my problem:
I used the Surface of Revolution Analysis plug in to create a colour map of a cylinder. I want to export vertical and horizontal profiles, but I get an error message: Internal error: null profile?!
Thanks,
Sarunas
Re: Surface of Revolution Analysis failed to export dxf
Ouch ;)
Can you send me maybe your files? (Cloud + profile). And the parameters? (a simple screenshot will do I guess).
My email is cloudcompare [at] danielgm.net (replace [at] by @).
SarunasBand
thanks for the reply. I sent you an email with cloud.
Regards,
Sarunas
Thanks! I was able to spot at least 3 bugs/glitches with your data ;)
The profile center was not always correctly taken into account, and the DXF exporter didn't like 'flat' profiles (i.e. a perfectly cylindrical shape).
The updated beta version can be found here:
http://www.cloudcompare.org/release/Clo ... in_x64.zip
