Hello! I am a big fan of CloudCompare and highly appreciate the new plugin for I/O Faro files.
I've installed CloudCompare 64 bits v2.6.0 in my laptop, with Windows 8.1 64 bits, and I have trouble with fls files. When I try to import a file it doesn't work:
[16:46:19] [Faro] Failed to connect to FARO LS runtime: Cannot instantiate FARO Open interface
(I have QFARO_IO_PLUGIN.dll in the plugin folder, and CloudCompare.exe.manifest in CloudCompare folder.)
I tried with the 32 bits version (2.6.0) and it works.
I can use the 32 bits version, no problem, but maybe this post help somebody with the same issue. The most surprising thing is that I have installed the 64 bits version in another laptop (same OS, same laptop model!) and it worked.
Thank you for your help.
Best regards.
[UPDATED]: I have just tried with CC 2.6.1 64 bits and it works perfectly.
PD: Added program version.
[SOLVED: V2.6.1]qFaro plugin not working on CC64bits (2.6.0). Working fine on CC32bits(2.6.0).(OS:Windows 8.1 64bits)
lopez.p.alejandro
Last edited by lopez.p.alejandro on Mon Feb 23, 2015 9:43 am, edited 1 time in total.
Re: qFaro plugin not working on CC64bits (2.6.0). Working fine on CC32bits(2.6.0). (OS: Windows 8.1 64bits)
Indeed, I was hopping that the new version would fix this ;)
lopez.p.alejandro
Re: [SOLVED: V2.6.1]qFaro plugin not working on CC64bits (2.6.0). Working fine on CC32bits(2.6.0).(OS:Windows 8.1 64bits
Then I am changing the topic state to SOLVED :)
Good work, thank you to all the developers!
