Page 3 of 4
Re: compare clouds for deformation-analysis
Posted: Mon Aug 15, 2016 8:53 pm
Oh, maybe you just miss the EDL shader ;) (see the 'Display > Shaders & filters' menu).
Posted: Wed Aug 17, 2016 10:54 am
by kayillerwhale
Hey Daniel,
you were right! it was just the missing shader :)
though i would be really thankful if you could have a look at the volume-calculation for the 2nd standpoint. after croppping the clouds to the same extends i get some really weird calculations. i know i'm really annoying but i need your help :(
6-7h:
Volume: -11.420
Surface: 99.919
Added volume: (+)0.002
Removed volume: (-)11.421
Matching cells: 93.0%
Non-matching cells:
ground = 3.5%
ceil = 3.5%
Average neighbors per cell: 7.5 / 8.0
6-8h:
Volume: -3.428
Surface: 99.977
Added volume: (+)0.005
Removed volume: (-)3.433
Matching cells: 93.3%
Non-matching cells:
ground = 3.4%
ceil = 3.2%
6-9h:
Volume: -11.774
Surface: 99.557
Added volume: (+)0.001
Removed volume: (-)11.775
Matching cells: 92.8%
Non-matching cells:
ground = 3.8%
ceil = 3.4%
6-10h:
Volume: 1.777
Surface: 99.814
Added volume: (+)1.796
Removed volume: (-)0.019
Matching cells: 93.2%
Non-matching cells:
ground = 3.5%
ceil = 3.2%
6-11h:
Volume: -5.679
Surface: 102.869
Added volume: (+)0.003
Removed volume: (-)5.682
Matching cells: 95.5%
Non-matching cells:
ground = 0.7%
ceil = 3.8%
Average neighbors per cell: 7.7 / 8.0
i really don't know what's happening there :S the volume-calculation jumps from -11 to +1 to -3.. also the surface at 11h is pretty strange. it's 3qm bigger than all the others. i haven't continued for 12 and 13h so far.
Edit:
ok i just had a look and compared the clouds graphically. they are shifted to each other. but how could this happen? here you can clearly see the shift between 6 and 7h. the scanner + tripod didn't move. otherwise i would have recognized that the level moved and the scanner isn't placed horizontal anymore. but that wasn't the case. any other suggestions? does it make sense to register the shifted clouds first and then do the m3c2 + volume-calculation?
http://www.directupload.net/file/d/4450 ... tk_jpg.htm
Here you can see that even after registrating two scans (6-7) it isn't really done precisely.
http://www.directupload.net/file/d/4450 ... vf_jpg.htm
http://www.directupload.net/file/d/4450 ... 56_jpg.htm
Edit_2:
6h-12h
Volume: -10.463
Surface: 102.711
Removed volume: (-)10.464
Matching cells: 95.2%
Non-matching cells:
ground = 0.9%
ceil = 3.9%
6h-13h
Volume: -10.121
Surface: 97.965
Removed volume: (-)10.123
Matching cells: 91.3%
Non-matching cells:
ground = 5.3%
ceil = 3.4%
Posted: Wed Aug 17, 2016 11:39 am
by kayillerwhale
Since the volume-calculation at 7h (volume: -11.420) and 9h (volume: -11.774) was quite similar, i did a comparison between these two clouds:
Volume: -0.407
Surface: 99.832
Added volume: (+)0.158
Removed volume: (-)0.565
Non-matching cells:
ground = 3.6%
ceil = 3.2%
as the calculated volume (-0.407) is likely to the results for the first standpoint, it's another sign that the scanner didn't move (imo).
Posted: Wed Aug 17, 2016 7:50 pm
Pay attention that the average number of (filled) neighbors is only 7.5 (ideally it should be 8 or almost 8). You can increase the grid step to reduce this effect (otherwise it may hinder the results).
Posted: Thu Aug 18, 2016 6:52 am
by kayillerwhale
i will try it in an hour but it still doesn't justify the big shifts between the scans. at least for the m3c2-distances there will be huge differences.. i don't know what happened there.
Posted: Thu Aug 18, 2016 7:01 am
Yes but I still don't have access to your data ;)
At least with more reliable volumes we will have a better basis to continue.
Posted: Thu Aug 18, 2016 9:55 am
by kayillerwhale
Ah ok ;)
So here are the results with an increased grid-size toi 0.04:
6-7h:
Volume: -11.677
Surface: 100.179
Removed volume: (-)11.678
Matching cells: 99.2%
Non-matching cells:
ground = 0.4%
ceil = 0.4%
Average neighbors per cell: 7.9 / 8.0
6-8h:
Volume: -3.504
Surface: 100.202
Removed volume: (-)3.506
Matching cells: 99.4%
Non-matching cells:
ground = 0.3%
ceil = 0.3%
6-9h:
Volume: -12.082
Surface: 100.078
Removed volume: (-)12.083
Non-matching cells:
ground = 0.5%
ceil = 0.4%
6-10h:
Volume: 1.823
Surface: 100.158
Added volume: (+)1.830
Removed volume: (-)0.008
Matching cells: 99.3%
Non-matching cells:
ground = 0.4%
ceil = 0.3%
6-11h:
Volume: -5.632
Surface: 100.408
Removed volume: (-)5.634
Matching cells: 99.5%
Non-matching cells:
ground = 0.2%
ceil = 0.4%
6-12h:
Volume: -10.390
Surface: 100.368
Removed volume: (-)10.391
Non-matching cells:
ground = 0.2%
ceil = 0.5%
6-13h:
Volume: -10.465
Surface: 99.110
Removed volume: (-)10.466
Matching cells: 98.2%
Non-matching cells:
ground = 1.4%
ceil = 0.4%
Posted: Thu Aug 18, 2016 9:59 am
by kayillerwhale
the surface values are kind of steady (differences caused by the empty cells again i guess) but as you can see the volume-calculation differs a lot.
edit: i just recognized that the 13h-cloud has a defect. there are some missing points because of a ship which covered a part of the wall. that's why the surface is smaller there. so i leave this cloud out.
Posted: Thu Aug 18, 2016 10:08 am
by kayillerwhale
i just had a look on the locations of the compared clouds (7-13) relating to the reference cloud (6h):
7h:
behind + left shifted
8h:
a little bit behind + minimal shifted to the left
9h:
nearly identical to 7h
10h:
nearly identical to 6h tiny bit in front and a bit to the right
11h:
a bit behind and shifted to the left (kind of similar to 8h)
12h:
behind and left shifted (nearly identical to 7h)
13h:
but as i already mentioned above: i have absolutely no clue why the clouds are shifted as the scanner-tripod didn't move. it was fixed and in level all the time.
Posted: Thu Aug 18, 2016 11:07 am
by kayillerwhale
here are the results of the volume-calcuation AFTER registrating the clouds to the 6h-cloud.
6-7:
Volume: -0.005
Surface: 90.133
Added volume: (+)0.176
Removed volume: (-)0.181
Non-matching cells:
ground = 0.2%
ceil = 0.2%
6-8:
Volume: -0.011
Surface: 90.093
Added volume: (+)0.169
Removed volume: (-)0.180
Non-matching cells:
ground = 0.3%
ceil = 0.2%
6-9:
Volume: 0.004
Surface: 90.086
Added volume: (+)0.180
Removed volume: (-)0.176
Non-matching cells:
ground = 0.3%
ceil = 0.2%
6-10:
Volume: 0.004
Surface: 90.091
Non-matching cells:
ground = 0.3%
ceil = 0.2%
6-11:
Volume: 0.003
Surface: 90.280
Added volume: (+)0.156
Removed volume: (-)0.152
Matching cells: 99.7%
Non-matching cells:
ground = 0.1%
ceil = 0.3%
6-12:
Volume: 0.004
Surface: 90.277
Added volume: (+)0.164
Removed volume: (-)0.161
Non-matching cells:
ground = 0.1%
ceil = 0.3%
6-13:
Volume: 0.000
Surface: 89.310
Added volume: (+)0.193
Removed volume: (-)0.193
Matching cells: 98.6%
Non-matching cells:
ground = 1.2%
ceil = 0.2%
