Page 2 of 2
Re: Cannot Open / Save Files MacOs
Posted: Thu Apr 17, 2025 6:40 pm
by francedc86
IT WORKS!!!!!!!
Thanks a lot you are great!
Posted: Tue Apr 22, 2025 2:06 pm
by Zizelind
Had the same issue after the update. What worked for me was giving CloudCompare full disk access in System Settings > Privacy & Security. Restarted the app after that and it could open/save files again. Worth a shot.
Posted: Sun Apr 27, 2025 7:48 am
by bjorn
OttoBot wrote: Wed Apr 16, 2025 11:07 pm In CloudCompare, you can find the display settings by following these steps:
Open CloudCompare.
Go to the top menu and click on Edit.
From the dropdown menu, select Preferences.
Am I blind or in the wrong location. I can't find Preferences:
Edit: Found it in Display -> Display Settings. The non-native dialog does not show my external drive, however.
I also tried giving full disk access in System Settings > Privacy & Security, but when I add CloudCompare it does not appear on the list.
Posted: Wed Apr 30, 2025 9:37 am
by Eva
I have the same problem, since the update I can't open or save anything.
I've managed to open files either by dragging directly or by deactivating ‘use native load/save dialogs’ in Display -> Display settings.
But I haven't managed to authorise access to the whole disk either, when I add cloudcompare to the list nothing happens.
Any idea where this might be coming from?
Posted: Fri Aug 29, 2025 1:53 pm
by paddywhells
Thanks bjorn. That fixed it for me.
Posted: Sat Aug 30, 2025 8:13 am
by nippotam
this trick works perfectly
Posted: Tue Oct 14, 2025 10:59 pm
by drjasonharrison
I wasn't able to initially find this discussion,
I did find this in my console log every time I tried to do "File > Open" in Cloud Compare:
Unable to display open panel (unrecognized error: Error Domain=com.apple.ViewBridge Code=14 "(null)" UserInfo={com.apple.ViewBridge.error.hint=-[NSViewServiceMarshal bootstrap:withReply:] caught NSInvalidArgumentException '*** -[NSUserDefaults setObject:forKey:inDomain:]: domain name cannot be nil or empty' with backtrace (
    "0   CoreFoundation                      __exceptionPreprocess + 176",
    "1   libobjc.A.dylib                     objc_exception_throw + 88",
    "2   Foundation                          -[NSUserDefaults(NSUserDefaults) setObject:forKey:inDomain:] + 420",
    "3   AppKit                              +[NSOSPDefaults _readFileListModeForIdentifier:inSaveMode:inDirectory:lastListForMediaBrowserMode:] + 524",
    "4   AppKit                              -[NSRemoteSavePanel(NSSavePanelLayout) _makeFinderKitView] + 416",
    "5   AppKit                              -[NSRemoteSavePanel(NSSavePanelLayout) _setupFileBrowserView] + 68",
    "6   AppKit                              -[NSRemoteSavePanel(NSSavePanelLayout) _initContentView] + 1544",
    "7   AppKit                              -[NSRemoteSavePanel initWithContentRect:styleMask:backing:defer:] + 488",
    "8   AppKit                              -[NSRemoteSavePanel initWithOptions:] + 476",
    "9   com.apple.appkit.xpc.openAndSavePan main + 708",
    "10  com.apple.appkit.xpc.openAndSavePan com.apple.appkit.xpc.openAndSavePan + 6440",
    "11  AppKit                              -[NSViewController _loadViewIfRequired] + 72",
    "12  AppKit                              __24-[NSViewController view]_block_invoke + 28",
    "13  AppKit                              NSPerformVisuallyAtomicChange + 108",
    "14  AppKit                              -[NSViewController view] + 160",
    "15  ViewBridge                          -[NSViewServiceMarshal _bootstrap:replyData:completion:] + 1308",
    "16  ViewBridge                          -[NSViewServiceMarshal bootstrap:withReply:] + 272",
    "17  CoreFoundation                      __invoking___ + 148",
    "18  CoreFoundation                      -[NSInvocation invoke] + 424",
    "19  CoreFoundation                      -[NSInvocation invokeWithTarget:] + 64",
    "20  ViewBridge                          -[NSVB_ViewServiceImplicitAnimationDecodingProxy forwardInvocation:] + 192",
    "21  CoreFoundation                      ___forwarding___ + 956",
    "22  CoreFoundation                      _CF_forwarding_prep_0 + 96",
    "23  CoreFoundation                      __invoking___ + 148",
    "24  CoreFoundation                      -[NSInvocation invoke] + 424",
    "25  CoreFoundation                      -[NSInvocation invokeWithTarget:] + 64",
    "26  ViewBridge                          -[NSVB_QueueingProxy forwardInvocation:] + 308",
    "27  CoreFoundation                      ___forwarding___ + 956",
    "28  CoreFoundation                      _CF_forwarding_prep_0 + 96",
    "29  CoreFoundation                      __invoking___ + 148",
    "30  CoreFoundation                      -[NSInvocation invoke] + 424",
    "31  CoreFoundation                      -[NSInvocation invokeWithTarget:] + 64",
    "32  CoreFoundation                      ___forwarding___ + 956",
    "33  CoreFoundation                      _CF_forwarding_prep_0 + 96",
    "34  CoreFoundation                      __invoking___ + 148",
    "35  CoreFoundation                      -[NSInvocation invoke] + 424",
    "36  ViewBridge                          __deferNSXPCInvocationOntoMainThread_block_invoke + 132",
    "37  ViewBridge                          __wrapBlockWithVoucher_block_invoke + 56",
    "38  ViewBridge                          deferredBlockOpportunity_block_invoke_2 + 356",
    "39  CoreFoundation                      __CFRUNLOOP_IS_CALLING_OUT_TO_A_BLOCK__ + 28",
    "40  CoreFoundation                      __CFRunLoopDoBlocks + 352",
    "41  CoreFoundation                      __CFRunLoopRun + 2384",
    "42  CoreFoundation                      CFRunLoopRunSpecific + 572",
    "43  HIToolbox                           RunCurrentEventLoopInMode + 324",
    "44  HIToolbox                           ReceiveNextEventCommon + 676",
    "45  HIToolbox                           _BlockUntilNextEventMatchingListInModeWithFilter + 76",
    "46  AppKit                              _DPSNextEvent + 684",
    "47  AppKit                              -[NSApplication(NSEventRouting) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 688",
    "48  ViewBridge                          __77-[NSViewServiceApplication vbNextEventMatchingMask:untilDate:inMode:dequeue:]_block_invoke + 148",
    "49  ViewBridge                          -[NSViewServiceApplication _withToxicEventMonitorPerform:] + 152",
    "50  ViewBridge                          -[NSViewServiceApplication vbNextEventMatchingMask:untilDate:inMode:dequeue:] + 168",
    "51  ViewBridge                          -[NSViewServiceApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 100",
    "52  AppKit                              -[NSApplication run] + 480",
    "53  AppKit                              NSApplicationMain + 880",
    "54  libxpc.dylib                        _xpc_objc_main + 816",
    "55  libxpc.dylib                        _xpc_main + 40",
    "56  libxpc.dylib                        _xpc_copy_xpcservice_dictionary + 0",
    "57  ViewBridge                          xpc_connection_handler + 0",
    "58  ViewBridge                          NSViewServiceMain + 360",
    "59  com.apple.appkit.xpc.openAndSavePan main + 156",
    "60  dyld                                start + 6076"
), com.apple.ViewBridge.error.description=NSViewBridgeErrorServiceBootstrap})
Posted: Wed Oct 29, 2025 7:14 am
Not sure if it's related, but have you looked at this discussion as well? https://github.com/CloudCompare/CloudCo ... ssues/2152
