Page 2 of 2
Re: M3C2 Plugin
Posted: Fri Apr 19, 2024 11:47 pm
by LiDoom
HeadLess wrote: ↑Thu Apr 11, 2024 8:13 pm
Well just an idea,
1. Export the two cloud Z coordinate to SF
2. Flatten the two cloud by setting Z coord to zero (create a new SF with static zero, then set coordinate from sf
3. Interpolate one of the cloud Z sf to the other one ( do not overwrite original.
4. Interpolate one of the cloud Z SF from the other one.
5. Convert SF to coord (the calculated distance)
6. Use rasterize tool to calculate 2.5d volume. If the clouds dense enough it will create a good enough calculation.
Thank you for this, but I am struggling with step 2-5.
I went ahead and just ran the 2.5d calculation. Is the volume result in meters cubed?
Re: M3C2 Plugin
Posted: Sat Apr 20, 2024 5:50 am
by HeadLess
It is in your cloud's unit cubed, so if your cloud is in meter then the volume is m^3
Re: M3C2 Plugin
Posted: Mon Jul 22, 2024 7:40 am
by Jopro
Hi there,
I exported my M3c2 field as a raster and imported it into qgis. Now i cannot find a find a way on how to export or safe my scalar field display ranges so i can display them in qgis as well. I tried multi band color or singleband pseudocloro in qgis but nothing worked so far.
I would appreciate any ideas and help :)
Re: M3C2 Plugin
Posted: Mon Jul 22, 2024 3:19 pm
Well, I'm not an expert in QGis or rasters in general, but clearly display features are not saved in a raster file. You'll have to recreate the color scale manually in QGis (at least this part should be possible).
But maybe other users will have better ideas ;)
