Cloud Compare to Reality Capture
DesmoMito
Re: Cloud Compare to Reality Capture
Post by DesmoMito »
Ok, I've followed your suggestions but I was not lucky. This is the the procedure I've followed, I hope you might help me to find a solution:
1) Opened Unregistred LAS (aereal LiDAR) with standard options (default value "non-zero" in Global shift/scale and "Preserve global shift on save" clicked)
2) Deleted all normals (Edit > Normals > Clear), TLS sensor and Octree (nothing to do for this step, everything was already empty):
3) Checked the correct position where to insert the TLS using a point picker.
4) Installed TLS (Edit > Sensor > TLS/GBL > Create)
5) Checked the Cloud depth buffer shown
6) Checked the position of the TLS inside the point cloud
7) Saved the point cloud as e57
8) Imported the e57 in Reality Capture as Unregistred
The file was imported correctly in RC but it creates just 1 lsp with the TOP view. I was expecting the view from the TLS that I added in CC (and also 6 different views) . Something went wrong but I don't know what.
Thank you.
3dvfx
Post by 3dvfx »
I am stuck with a similar problem. I have a (unordered?) Pointcloud as a .Las file and need a high quality mesh, the Poisonn Recon seems to smooth all detail away so i wanted to try reality capture. I found this thread for the workflow but im stuck at how to save/export a e57 File? I cant save as e57 file. I dont have Faro Scene, is there a way to get a capture reality file without Faro software?
Thank you very much
