Page 2 of 2
Re: Method to compute spacing between points
Posted: Tue Sep 24, 2019 7:00 pm
by thierry
I've note something else using the approx density method.
The computing seems to crash above ~130 millions points, it doesn't really crash as the process is seen "no answer" but consume a tiny CPU power around 6/7%. But it stoods for hours so I stoped it.
Does CC has a limit in points for computing ?
Posted: Tue Sep 24, 2019 7:19 pm
Hum, there's always a limit which depends on the computer memory... If it's full, then Windows may start to swap and any process with take ages (without consuming much CPU power, as the time is mostly spent on 'swapping').
But generally you wouldn't hit this limit on a standard PC before several hundreds of million points...
Posted: Tue Oct 01, 2019 7:30 am
by thierry
Very unlikely as I got a 128GB RAM PC. I will watch for this nevertheless, thx.
Posted: Tue Oct 22, 2019 5:59 am
by geonature
i have the same problem...but i cut the point cloud in more small area, and the software work well..
