Page 2 of 2
Re: Problem with Cross Section tool
Posted: Sun May 13, 2018 7:51 pm
Nope. You have to set the slice as thin as possible (it will depend on your cloud density). If it's too thick, you'll see the same problem you faced before. Il will be less accurate.
The you set the reminding with the gap value.
Posted: Mon May 14, 2018 6:17 pm
by mirt83
I got.
Resuming, to have a good result I have to set a slide thickness to 3 mm and a gap of 0.097 to extract a serie of contours every 10 cm.
Thank you very much for the patience Daniel
Posted: Mon May 28, 2018 2:47 pm
by mirt83
I have another problem. I attach a screenshot
Posted: Mon May 28, 2018 8:39 pm
Have you asked CC to 'split contour(s) on longer edges'? In this case you probably to reduce the 'Max edge length' parameter, or simply disable this option.
