Maximum file's size
skarab
Re: Maximum file's size
Post by skarab »
daniel wrote:Something like 'Edit > Scan grids > Delete'?
I don't found it. The only option that contains " scan grids" is "Edit > Mesh > Mesh scan grids"
Sorry for the delay, i don't receive notifications
Edit : I effectivly "scan grids" in the properties but no way to modify them. Their number is bigger than the initial number of initial .fls. Ideas ?
Oh you must be right. This means Romain never pushed this modification :D (I'll ask him about this).
Each time you segment a cloud, the grid is duplicated. And I guess if you merge the subsets afterwards, the grids are not 'merged' but copied next to each other...
skarab
Post by skarab »
daniel wrote:Oh you must be right. This means Romain never pushed this modification :D (I'll ask him about this).
Thanks for the answer. Let me know if there a modification or something I can do
Edit :
I'm still asking why my files are so big. The grids have a weight ? The same with or without have a very different weight.
Romain just pushed his modifications. It's integrated in the latest 2.9 beta version (online).
(Scan grids are quite big indeed ;)
skarab
Post by skarab »
Thanks for all. I will try it with my colleg today. Do you know if there a way to install different version ? We have many problems with .fls compatibility since we try to install to install 2.7 and 2.8.1 simultanatly.
I bet it's always possible to install CC in different folders? I'm just not sure if the installer tries to delete the previous version whatever the destination folder is...
And what are the issues you have exactly with the FARO plugin?
