How to export properties such as Box center and Box dimensions
Ph.Wo.
Re: How to export properties such as Box center and Box dimensions
Post by Ph.Wo. »
Hey,
i need the same feature, but my knowlege about c++ is realy bad. So if anybody has something that will work, or maybe have a nother solution to geht the bounding box for a lot Pointclouds, please let me know.
Have a nice day,
Philipp
Well, the code modifications are really easy.
In the current version, after the line 8454 of mainwindow.cpp (csvStream << "meanZ;";) you can add:
csvStream << "minX;";
csvStream << "minY;";
csvStream << "minZ;";
csvStream << "maxX;";
csvStream << "maxY;";
csvStream << "maxZ;";
And after the line 8479 of mainwindow.cpp (csvStream << G.z << ";";) you can add:
csvStream << cloud->getBB_recursive().minCorner().x << ";";
csvStream << cloud->getBB_recursive().minCorner().y << ";";
csvStream << cloud->getBB_recursive().minCorner().z << ";";
csvStream << cloud->getBB_recursive().maxCorner().x << ";";
csvStream << cloud->getBB_recursive().maxCorner().y << ";";
csvStream << cloud->getBB_recursive().maxCorner().z << ";";
my_cc
Post by my_cc »
daniel wrote: Thu Sep 13, 2018 7:49 pm Well, the code modifications are really easy.
I changed code according to the instructions above, and tried the command below to install the CC.
1. mkdir build & cd build
2. cmake -DCMAKE_PREFIX_PATH=C:\Qt\5.15.2\msvc2019_64 ..
3. cmake --build . --config Release
4. cmake --install .
Then, I got the error shown below during the building step 3.
C:\Users\taoliu\CloudCompare\build\qCC\ui_graphicalTransformationDlg.h(322,29): error C2039: 'setStepType': is not a me
mber of 'QDoubleSpinBox' [C:\Users\taoliu\CloudCompare\build\qCC\CloudCompare.vcxproj]
C:\Users\taoliu\anaconda3\Library\include\qt\QtWidgets\qspinbox.h(113): message : see declaration of 'QDoubleSpinBox' [
C:\Users\taoliu\CloudCompare\build\qCC\ui_graphicalTransformationDlg.h(322,59): error C2039: 'AdaptiveDecimalStepType':
is not a member of 'QAbstractSpinBox' [C:\Users\taoliu\CloudCompare\build\qCC\CloudCompare.vcxproj]
C:/Users/taoliu/anaconda3/Library/include/qt\QtWidgets/qabstractspinbox.h(56): message : see declaration of 'QAbstractS
C:\Users\taoliu\CloudCompare\build\qCC\ui_graphicalTransformationDlg.h(322,1): error C2065: 'AdaptiveDecimalStepType':
undeclared identifier [C:\Users\taoliu\CloudCompare\build\qCC\CloudCompare.vcxproj]
C:\Users\taoliu\CloudCompare\build\qCC\ui_graphicalTransformationDlg.h(344,31): error C2039: 'setStepType': is not a me
C:\Users\taoliu\CloudCompare\build\qCC\ui_graphicalTransformationDlg.h(344,61): error C2039: 'AdaptiveDecimalStepType':
C:\Users\taoliu\CloudCompare\build\qCC\ui_graphicalTransformationDlg.h(344,1): error C2065: 'AdaptiveDecimalStepType':
Step 4 gave me the error below.
C:\Users\taoliu\CloudCompare\build>cmake --install .
-- Install configuration: "Release"
-- Installing: C:/Program Files (x86)/CloudCompareProjects/CloudCompare/CCAppCommon.dll
-- Installing: C:/Program Files (x86)/CloudCompareProjects/ccViewer/CCAppCommon.dll
-- Installing: C:/Program Files (x86)/CloudCompareProjects/CloudCompare/CC_FBO_LIB.dll
-- Installing: C:/Program Files (x86)/CloudCompareProjects/ccViewer/CC_FBO_LIB.dll
-- Installing: C:/Program Files (x86)/CloudCompareProjects/CloudCompare/CCPluginAPI.dll
-- Installing: C:/Program Files (x86)/CloudCompareProjects/ccViewer/CCPluginAPI.dll
-- Installing: C:/Program Files (x86)/CloudCompareProjects/CloudCompare/CCCoreLib.dll
-- Installing: C:/Program Files (x86)/CloudCompareProjects/ccViewer/CCCoreLib.dll
-- Installing: C:/Program Files (x86)/CloudCompareProjects/CloudCompare/QCC_DB_LIB.dll
-- Installing: C:/Program Files (x86)/CloudCompareProjects/ccViewer/QCC_DB_LIB.dll
-- Installing: C:/Program Files (x86)/CloudCompareProjects/CloudCompare/QCC_GL_LIB.dll
-- Installing: C:/Program Files (x86)/CloudCompareProjects/ccViewer/QCC_GL_LIB.dll
-- Installing: C:/Program Files (x86)/CloudCompareProjects/CloudCompare/QCC_IO_LIB.dll
-- Installing: C:/Program Files (x86)/CloudCompareProjects/ccViewer/QCC_IO_LIB.dll
CMake Error at qCC/cmake_install.cmake:37 (file):
file INSTALL cannot find
"C:/Users/taoliu/CloudCompare/build/qCC/Release/CloudCompare.exe": File
exists.
cmake_install.cmake:39 (include)
I guess it's an issue with the version of Qt you are using as 'setStepType' has been introduced in version 5.12.
Providing the path to Qt as 'CMAKE_PREFIX_PATH' may not be sufficient to force Qt to use this particular version. You should use the GUI version of CMake and check which version is actually found by CMake.
my_cc
Post by my_cc »
Thank you, Daniel. I was able to compile it successfully following the tutorial in one YouTube video, which uses GUI CMAKE rather than the command line of CMAKE.
Helpful YouTube tutorial link https://www.youtube.com/watch?v=hjT7WQLbqqE
virenbachani
Post by virenbachani »
daniel wrote: Fri Feb 23, 2018 8:51 am Yes, it basically consists in 'hacking' the code of the 'Tools > Batch export > Export cloud info' method.
You can find it in the big 'mainwindow.cpp' file, and the method is called MainWindow::doActionExportCloudInfo.
The current versions saves various pieces of info, but you should be able to comment a lot of lines. And to get the bounding-box extents, just call the 'getBoundingBox' method of each 'cloud' instance.
Hi Daniel, has there been any updates to this solution? I have not found any files with those names. If you could please help me out with this?
kartikanur.rp
Post by kartikanur.rp »
Hi, is there any updates regarding this issue?
Not that I am aware of.
