commande line STAT_TEST
williamP
Post by williamP »
I want to batch the command line STAT_TEST.
I wrote this script :
cd "C:\Program Files\CloudCompare"
CloudCompare.exe -O C:\Users\Desktop\resultat_comp\%VrFchRcnt% -STAT_TEST GAUSS mean value sigma
where VrFchRcnt is a txt file.
The problem is that CC displays an error message : "invalid parameter: mean value after Gauss".
I try to put mean value and sigma between () or {} and [] but the message stay, I don't know how i have to write the distrib parameters.
Thanks you for your answer !
PS: it is possible to know the mathematical methode that is used to calculate sigma please ? :)
Re: commande line STAT_TEST
Actually the 'Statisticai Test' tool is meant to test al points (and its neighbors) SF values against a specified Normal distribution representing the scanner noise for instance (to know if the SF values are following this distribution (e.g. are part of the noise) or not.
So you actually have to specify the mean and standard deviation values (with numeric values).
I guess that this was not your aim? You just wanted to extract the mean and standard deviation from a (cloud with) scalar field? If yes, then it's not possible at the moment (this function has not been exposed in command line mode).
williamP
Post by williamP »
thanks you for remarks !
Yes, I want to extract the mean and standard déviation.
