Hi I am new to Cloud Compare so please forgive any stupid questions. Recently I have undertaken some high definition sonar scans of a bridge structure and I am now trying to use the data to identify any areas where defects occur. I am able to bring the data in and I was trying to create a mesh of the data , however every time I try this the software crashes, what am I doing wrong. Also is there a workflow for doing this procedure and is this the best way to depict data in high definition.
Thanks in advance.
Mesh
Re: Mesh
What meshing tool are you using? And what version of CC? (on which OS?).
A crash shouldn't occur anyway (apart for some old buggy versions).
chughesfish
Re: Mesh
We are using CC V2.5.5.5.2 and Delaunay 2D(best LS plane)
Re: Mesh
Can you try with a much more recent version (2.7 or at least 2.6.3)?
And is the point cloud big?
chughesfish
Re: Mesh
Ok, I will try with a more recent version, about 6.5 million points in the full file but I have tried with a smaller file also.
Re: Mesh
Yep, it's not that big. A newer version should work without any issue.
