Hi Daniel!
Thanks for your software. I have an issue when i want to see my point cloud from the camera that i created with the bundle.out file. In other words, I would like to have a view of my point cloud from like if it was the camera (here thermal camera) that took it. When i use the viewport from the sensor, the point cloud is not in the frame designed by the camera sensor (see capture.JPG below). Is it a problem with the coordinates of the point cloud or with the bundle.out file? Can't understand what happened there.
Thanks in advance and best greetings.
Olivier Dubas
P.S. : If you speak French, it's perfect for me!
Camera Sensor / Point Cloud / Viewport
OlivierDubas
- Capture.JPG (131.17 KiB) Viewed 2619 times
Re: Camera Sensor / Point Cloud / Viewport
If you want to continue in French, then we should do it by email (cloudcompare [at] danielgm.net). And it would be probably easier for me to debug if you can send me the files (.out + image).
