Faro IO
Old_Shatterhand
Faro IO
Hello Daniel!
I am a beginer of CC.
I would like to use the plugin qFARO_IO_plugin in my CloudCompare 2.6.3, what procedure should I follow?
Running on Windows 7, qFARO_IO_plugin is not in the Plugin menu. The dll exists in in the CloudCompare/plugins folder.
Re: Faro IO
Normally to use the FARO plugin you have to use the installer, and check the 'install FARO plugin' option.
Check also that there's a 'cloudcompare.exe.manifest' file next to CloudCompare's executable file.
And last but not least, you can check if there is an error message in the Console regarding this plugin when starting CloudCompare.
Old_Shatterhand
Re: Faro IO
Thank you for quick answer!
In the console near the Faro plugin I dont find error massage, I have Faro Scene on my computer, but in the Faro Ls directory just 2 uninstaller file exist. Is it a problem?
Last edited by Old_Shatterhand on Fri Sep 23, 2016 12:37 pm, edited 1 time in total.
Re: Faro IO
Well, seems ok for what I know...
Can you check the list of loaded plugins (Help > About plugins) and see if the Faro plugin is there?
Old_Shatterhand
Re: Faro IO
Yes, I look Faro plugin in Help/About plugin.
Re: Faro IO
Then you should see the Faro files filter in the loading dialog, don't you?
Old_Shatterhand
Re: Faro IO
Ok, I look in the open list, but can not save (export) to Faro format.
Re: Faro IO
Ah! You can't do that. The Faro SDK doesn't allow for this...
Old_Shatterhand
Re: Faro IO
Any other format to Faro? The e57 not working for me, every point black in Faro Scene.
Re: Faro IO
I don’t know Scene very much, but you should be able to load E57 files at least, can't you?
