can't open pcd files
RafouLeKaribou
Post by RafouLeKaribou »
Hello everybody!
I recently (10 mins ago) downloaded cloud compare using this method : https://bintray.com/ornis/CloudCompare/ ... dmore#read.
I'm on Wily Werewolf distrib.
But when I try to open pcd files, I have the error [Load] Can't guess file format: unhandled file extension 'pcd'.
Do someone know how to fix it?
Thanks a lot
Re: can't open pcd files
I believe PCL was not available in the packages of Ubuntu 15.10 (or something like that - Romain would tell you more about this).
Therefore the PCD format (which requires PCL) can't be read by this version.
I bet you can compile it yourself to overcome this issue?
RafouLeKaribou
That's strange, cause i'm actually working with PCL on ubuntu 15.10.
I'll wait Romain's answer and do as you said. I'll uninstall then compile it myself. But it's kinda sad :'(
Romain.Janvier
Post by Romain.Janvier »
Could you test that:
https://we.tl/BjhwYzfR3U
thanks,
R.
RafouLeKaribou
Owh! Works like a charm!
What a fast and solid answer! :)
Merci beaucoup! :)
Have a nice evening!
Romain.Janvier
thanks a lot for the test.
I will update the repo with this version tonight (GMT)
R.
RafouLeKaribou
If i'm the Beta Tester, i'll report anything I saw.
There is still a problem when opening and saving PCD, rgb values are not taken. So objects appear with default color, and they lost the informations when saved.
Romain.Janvier
You can report anything you see :) If you think it's related to the package or Linux dependent, I should try to answer.
According to the code of qPCL, it's not the normal behavior, RGB values should be loaded. Unfortunately I'm not an user of this plugin and I haven't any environnement to reproduce your "bug" so I can't tell you more.
R.
paulrbarnard
Post by paulrbarnard »
I have the same problem on the Mac build 2.7.
Is there a Mac build available that opens .pcd?
Many thanks
Nope, PCL is not properly supported on Mac OS.
