precise density computation
wangyh9098
Post by wangyh9098 »
Hi I got a problem. When I use the local precise volume density computation last week, it works very well. But it turns out to be not functional, that is, Cloud compare stop working when I run this tool (I am using the same computer). Is there any way to fix this problem?
Re: precise density computation
Are you using the exact same version? Which version by the way?
wangyh9098
Yes, it is the exact the same version. v2.6.1
Can you try with the latest beta version? (2.6.2 beta)
Otherwise can you send me the cloud (and the radius you used)?
