Currently working on a project of point cloud classification and vectorisation to end my engineer studies, I've been working on the combination of CC and Canupo
Thanks to the work (and precious help) from Dimitri few weeks ago, I've been able to perform a classification on a small urban tile of MMS scan from a pretty large project.
As a first step of this project, I'm pretty happy with this first result of the classification, using canupo to detect some shapes (piles, vegetation, vertical and horizontal planes for now). But as describe previously, this is only a little piece of a way larger area I would like to classify automatically.
And this is where my issues start appearing; I have for now, no idea how to find the command line version of CC to try to create a batch on many tiles. Where can I find it?
I have found the Canupo command line version but for now haven't been able to run it properly, for example when I wanna subsample my point cloud, using "resample.exe" with a spatial parameter and a 0.02 radius, and the "subsample" function with the same parameters on the point cloud, I have much fewer points using the .exe of canupo; how is it possible?
For no, the classification via the command line version of canupo either crashed (still don't know why) or a result with only few lines remaining in the point cloud (probably coming from the fact that I'm working with large coordinates and I can't use a global shift).
If you have any hint for me to work on to create my batch processus, that'd be perfect!
Thanks in advance,
Corentin Blanc,
Elève ingénieur INSA Strasbourg 5ème année,
Stagiaire FIT Conseil Nantes.
