Dear Daniel,
I´m having some trouble with the command line for the -APPROX_DENSITY -SURFACE command. I´m writing:
CloudCompare -O option-0000.ply -APPROX_DENSITY -SURFACE
But I do not get the SURFACE command recognized. Also tried with {SURFACE}
Maybe it is a silly question.
Many thanks and congratulations for your amazing work!
Best regards,
Carlos
Surface density in command line
Re: Surface density in command line
Have you tried:
-APPROX_DENSITY SURFACE
ccastilloro2
Yes, I tried also -APPROX_DENSITY SURFACE, but it didn´t work.
I finally moved to the DENSITY command. The right solution for me was -DENSITY 0.1 -TYPE SURFACE, where 0.1 was the sphere radius.
Many thanks!!
Carlos
Many thanks!!
Carlos
Indeed, the -TYPE was missing.
While it's much better to use the 'real' density estimator (DENSITY), it should also work with APPROX_DENSITY:
-APPROX_DENSITY -TYPE SURFACE
